Hi all, I have a AL-320G lathe and having issues with the "C" clips that hold the gears on. Is there a better type or do i just put up with it.
Also is there a way around having to change the gears back to default so that power feed can be used ? I've been told my fault I bought the wrong lathe.
Kpar
I understand your frustration when someone tells you its your fault that you were not aware of a detail like a e clip. I find it sort of an insult.
To get around the issue another lathe with a more convenient system would probably been at least a 1000 dollars more. So there is that issue.
For the immediate problem they make e clip installation and removal tools. They range from expensive to about 20 bucks for a set. these tools might take some of the pain out of removing the e clip. I would say this cuts the time in half to to remove them and install them. My guess is you will only need one tool for the size you use.
Whether or not you use an eclip or a nut to retain the gears it requires time to re set the lathe. However, my lathe uses the feed rate based on the gears and if the thread is fine its power feed works ok. Sometimes I will adjust the feed rate with the gears. Not often but I will do it.
The other option which is a project is to work on an electronic feed screw. Claus 42 on you tube has a whole set of videos on this conversion. Its one I have been considering but I just dont do enough work to make it. worthwhile other than doing the project for fun. Punch a button and you are done. Just be sure the calculations are correct.
Take Care
HMEL
