I have need of a vise stop with my current project. I already have a crappy one I threw together a couple years ago. It has served me well but its time for a better one. This time Im also going to make it better looking as well.
You can see the old one in use here.
All the pieces came from the scrap box, I bit of aluminum and a short piece of 3/16 O1 drill rod.
The dimensions of the aluminum after clean up are roughly 2.500 x .375 x .750 inches. The drill rod is about 3 inches long.
First thing after clean up was mill out a slot for it to slide in. The slot is 5/16 wide and 1 inch long. The bolt on the vise is 8M, the 5/16 slot clears it nicely without being too loose. The slot starts .800 from one end, this will also be the end for the cross bar. After milling the slot I drilled and reamed a 3/16 inch hole .190 inches from the same end.
Sorry for the dark picture, I forgot to turn on the flash.
The piece was then set at a 30 degree angle and slit.
After slitting the top was countersunk for a #8 SHCS. Everything was kept at the 30 degree angle.
The hole was then drilled for the 8-32 screw, then clearance drilled up to the slit. Then it was tapped.
After a little clean up this is what I ended up with.
It fits the vise nicely and is way more adjustable than the old stop.
Thanks for looking.
Thanks for looking.
