I meant to ask last time...how did you make the collet blocks? In particular, how did you keep it square and true to the collet's center?
Thanks.
Thinking about your 'auto-stop'...with my purchased collets, once the nut is nearly fully engaged, there's still a good 3/32 or more available before it gets to the block. Could a strip of metal with a large enough hole be put there (between the nut and block) and extended out enough to be used as a stop? How thick should something like that be? I suspect it should be made of steel?
