- Aug 25, 2007
- 3,890
- 715
I can't seem to get excited about resuming work on my Bessemer model, so I've decided to tackle another engine model that has been on my list of projects to do for some time now. This is the Fairbanks 80hp, 3 cylinder.
Castings have been available for an IC version and I've seen several of these at model engine shows. Here is a video of one such model...
[ame]http://www.youtube.com/watch?v=Gqsi6Z2qsEI[/ame]
My engine will be somewhat smaller with a 3/4" x 7/8" bore and stroke. And, although my engine will be four stroke in operation, it will be powered by compressed air using over head intake valves and my slave exhaust valve. For those of you familiar with the IC model, and perhaps the original engine, my version will have the main bearings and caps contained in the upper crankcase half instead of the bottom. While I want to adhere to the original scale dimensions as closely as I can, my model will be somewhat stylized and probably not have all the detail seen in the original. However, I will try to add some bling and make it somewhat interesting.
Finally, I'm making a serious attempt to model each part in Alibre before constructing that part, so I should end the project with a complete set of drawings. Below is the first installment showing the upper crankcase half. It will be machined from solid aluminum or cast iron, yet to be decided. If you download the 3D PDF, you can click to activate it, then rotate the part by holding down the mouse and dragging it around.
https://dl.dropboxusercontent.com/u/29733857/Crancase%20Top.pdf
