Skip.foley
New Member
- Jun 18, 2010
- 1
- 0
Im about 98% finished building a 1.6 scale Shay. Its 5 long 12 wide, weighing in at 450lbs. It needs to make more steam. I can tows 1500lb at 5mph but slows to 2mph on any incline, pressure drops from 100psi to 45psi with the burner at max output. The burner is aspirated and its size limits the air intake quantity thus limiting itss output power. The new burner should produce 8k btus each times 6 for about 48k btus.
I dont have the skills to cut the 6 .038 slots in the burner tops and need some advice. Ive look at a .040 endmill at $70 that Id probably break. I have a 2 diameter .040 slitting saw. The slots are .5 long and about .25 deep so the saw only cuts a shallow incomplete slot.
Thanks in advance for any help.
