steamin
- Aug 25, 2009
- 233
- 141
Greeting, I have a thread started about the La France engine build under "A Work In Progress". What I would like to share here is some thoughts and feelings about my approach to the boiler for the La France. I did read through many of the postings under this topic and they were very encouraging about what I have in mind.
Basically, I am building the boiler from "Pressure Vessel Quality" materials except for the flue tubes. They will be copper. The reason for the all steel boiler is my skills for TIG welding is far better than my skills for silver soldering such a massive assembly and having everything stay in alignment.
The first picture shows a piece of 0.500" by 0.032" wall thickness that has been swaged into a piece of 0.250" thick steel that represents the flue tube sheets in my boiler. The hole in the 1/4" thick stock was reamed with a #1 taper pin reamer. The larger diameter of the hole would be on the none pressure side. The second picture shows the assembly next to a punch with the same amount of taper as the hole in the 1/4" stock. Next to the punch is a series of hardened steel balls that I had on hand; 0.625" dia., 0.875" dia., and 1.062" diameter. I used these balls in secession starting with the smaller ball first to flare the end of the tube outward. Then a small ball peen hammer was used to flatten the copper down to the surface of the 1/4" plate. I left 0.100" protruding from the 1/4" plate for this process. I do believe this process will work for my flue tube installation unless someone has any reservations.
The technical hurdle at this point is the punch. It was a bear to remove and I will not be able to remove it the way I did for this experiment when installing the flue tubes in the boiler assembly. So it is back to the drawing board on the punch. I am thinking along the lines of an expandable tool of some sorts ???
So please if you have any thoughts or question, fire away !
