I have an older "Jet" 14" vertical bandsaw, which is billed as being able to cut "wood or metal". It has a jackshaft and second set of pulleys, as made in the factory. As near as I can figure out, the blade speed on its slowest setting is 677 foot per minute. This works great on brass and aluminum, but according to everything I read on the subject, it should have a blade speed of 250 foot per minute to cut mild steel. I am about to add a second jackshaft and set of pulleys which will slow it down to the 250 FPM, but I am curious as to whether it will still cut my brass and aluminum bits okay at that reduced speed. I don't want to have to frig around changing belts to different pulley steps when I switch from cutting steel to cutting aluminum.
