Art K
- Jul 4, 2012
- 218
- 39
Hi,
I thought I would get a little head start and then post, so that I can keep the gaps to a minimum. Also when I've had enough in the shop I can go inside sit back relax and have a cold one while I tell what I've been doing.
A little info if you are not familiar with Val. It is an engine designed by Brian Fairey, and is featured in Model Engine Builder magazine. It is 1 cubic inch, 1.124" bore X 1.1" stroke. It has overhead valves and is setup like an RC airplane engine, with a flywheel instead of a prop.
I talked with Mike Rehmus about this engine and some modifications I intended to make. I am in the camp that doesn't like built crankshafts, I minimized the amount of pieces from 4 to 2(not including gears). As George Brittnel would advise using 1144, that is what I used. This is actually take two on the crank, I scraped the first one on the threads, then broke down and bought a die. I figured the fuel line I used to protect the finished throw flexed enough to go down the middle, won't do that again. I did recycle it as the cam driver side of the crank.
Art
Art
