- Jun 4, 2008
- 3,285
- 630
Having read all of the ball turning threads of late, I decided to have a go using the "human CNC techique" this evening. I ran Marv's program to produce cutting schedules for both .04" AND .02" increments for a 1" diameter ball. I ended up using the .04" schedule.
My camera is in for repairs, so no photos currently available.
The ball is intended to replace the plastic on the end of the handle of the QCTP, which has a 3/8-16 thread. I found a piece of 1" dia. 6061 aluminum, chucked in a 5C collet, and turned down a 1.5" length to 1/2" diameter. This was drilled and tapped. I then reversed the piece chucking the handle in a .5" collet, and faced the exposed giving a 1" length of 1" diameter which would become the ball.
I followed Marv's schedule using a LH bit for half the ball, then mounted a RH bit to form the inner half. Perhaps using a parting tool would be quicker. The cutting went very fast, less than 10 minutes, as aluminum cuts easily. Subsequently I measured to find that my diameter was .997 and my length was 1.02, so I was .005" oblong.
Now I coated the ball with Dychem, and started smoothing with a file until none of the color remained and I could not see any lines from the "slices". I followed this up with 3 grades of emery cloth, 2 grades of Scotchbrite, and finally Mother's metal polish. Total time from first cut to polish was about 45 minutes, so probably equal to setup and cutting time with a ball cutter.
However, my result was not exactly spherical, with the end being rather flat. I suspect that to get a really good sphere a lot more filing would be required, with reference to a radius gauge perhaps. For the purpose of a handle (which I suspect a great many home shop balls are used for), my "ball" is perfectly OK.
Note that in running Marv's program, I selected the "x-axis" method. The alternative is "angle", which may give more cuts on the ends, where it's more critical to get a proper shape.
