FWIW, the 'tank' area is only about 3/8" diameter and also partly stuffed with what looks like a cigarette filter or two, so there's not that much volume there.bentprop said:I have one of those pencil torches,but my biggest problem seems to be getting enough gas into the thing.It never seems to take a full fill :-\
shred said:...they're a good source of butane tank filler valves..
Probably not worth trying to unclog them. The ones I took apart, the 'jet' was only a tiny hole punched in a piece of foil which is sandwiched in one of the screw joints. As soon as you undo the joint, the foil falls off and is very difficult to replace successfully. If you reassemble without the foil, you get a low-budget flamethrower.Vernon said:Hmmm... both of mine now appear clogged. :-\
Bernd said:
