I'll have to post another pic in it's present state to show how it does in the vertical mode. The cart's so full of metal it's center of gravity is now low enough to prevent pushing it over if you wanted to. ;D
Speaking of vertical mode, did you see my post a while back with the drawing of the little 1/4" steel table that's sized to allow it to be permanently bolted on? You can then use it to cut in either mode without having to screw on & off that silly sheetmetal table it comes with.
