3/4" Case
bobden72
Plymouth UK
Hi I started building Rodeys Tractor and decided to make it more like a Case 65, you will notice the tapered stack. I built a 3" version about fifteen years ago so adding improvements from memory and pictures of mine. These few pictures are of the flywheel clutch which I have now finished and is working. I also intend fitting Wolf valve gear, a trunk guide, dummy heat exchanger, lubrication pump and dummy governor.
