TinkerJohn
Active Member
10 x 30 Metal Lathe for Sale--Excellent Lathemaster metal lathe for the home shop. Used for hobby making model engine projects only. Includes 3 and four jaw chucks as well and steady rest and traveling rest. Also includes Phase II quick change tool post and one holder as well as complete owner’s manual. It is currently in my shop and working, serious buyers are invited to test run the lathe. The lathe weighs approximately 350 lbs. and buyer will be responsible for moving after purchase. Click here for YouTube video of lathe:
Here are some specs:
Swing over Bed: 250 mm (9.84 inches)
Swing over Cross Slide: 5 7/8"
Distance between centers: 750 mm (29.52 inches)
Carriage Travel: 25"
Spindle speeds: 6
(125, 210, 450, 620, 1000, 2000 rpm)
Longitudinal Feeds: 2 (.005,.010)
Inch Threads: 12 (8 - 40TPI)
Metric Threads: 12 (.4 - 3mm)
Cross Slide Travel: 4 1/2"
Compound Travel: 2 5/16""
Tailstock Spindle Travel: 2 3/4"
Tailstock Taper MT2
Spindle Bore: 20mm (3/4")
Spindle Taper: MT3
Motor: 3/4 HP, 110V/60Hz
Machine Size: 56"x19"x18 1/2"
Machine weight: 330lbs.
Lead Screw: 12 TPI
The dual prismatic ways are induction hardened and precision ground, supported on a rigid frame--The spindle is supported on quality tapered bearings.
Feed ratio and thread selection are set with included metal gears--The lathe cuts left hand threads and make cuts away from the chuck with the easy installation of a feed reverse gear (Included)
The motor is forward and reverse switching--The lead screws are true inch pitch--Hand wheels and dials are all metal. Scales are satin finished, and clearly engraved in Imperial measure.
Asking $2200 and located in Whitehouse, TX (65 Miles East of Dallas, TX)
Contact: John Robertson ([email protected])
Spindle speeds: 6
Tailstock Taper MT2
Spindle Taper: MT3
Lead Screw: 12 TPI
