My mill's 5/8-capacity drill chuck is mounted on an R-8 to JT6 arbor that requires lots of Z-axis movement whenever I switch from milling to drilling. That's a pain on a Sieg X-3 which has a geared-down Z-axis. Lots of cranking. What I would really like, is a nice, medium-small 3/8"-capacity Rohm chuck and mount it on a "stub arbor" (probably not using that terminology correctly) that would fit to the chuck and then slip into the 3/8 R-8 collet that gets the most use on my machine. That way I could switch from edge finder to 3/8 end mill to drill chuck without removing the 3/8 collet.
I have searched Enco and Grizzly for such a device (ie, JT1, J2, or J33 that transitions to a straight 3/8" shank) with no success. Does such an adaptor exist for purchase? I do not own a lathe (yet) so can't make my own...
