vega 9cc V-twin
bananaman
Hi everybody
here are a few pics of my Vega that i have been building.
not much more to do just set the timing, a few fuel bits and then decide what to put it in!!!!
tell me what you think of it 8)
That is a very nice looking engine.
I am curious though, why are the valve push rods so long?
I would enjoy seeing some of your build pictures.
I always learn so much by seeing how other do there machining.
SAM
Hi. I like it. Its very nice and displays excellent workmanship! :bow:
I.m not well versed on small gasoline engines, and don't know the model. so could you post specifications. And were the plans came from, ect.....I'm sure other members would like to know too.
Thanks.
-MB
SAM
hi Sam
the push rods are not long what you can see is the bolts to adjust the valve movment as the timing is not done yet i haven't trimmed them down
sory no build pics though most of it was done on a C.N.C vertical machinin center
thanks for the reply ;D
That looks very nice. Have you put a slight taper on the cylinders or is that an optical dilusion on my part.
As you know I still have much to do in my build. I am interested to know what you did about the crankshaft balance. The spec calls for high density metal but I have been unable to find a supplier.
Be sure to post us a video when you fire it up.
Peter.
Peter.
hi Peter
yes there is a taper on the cylinders just a little bit to make it my own
i used lead to balance the crank, put a heavy chamfer on each side of the hole then fill them up with molten lead fingers crossed this will work ???
Great job!!
bananaman,
Nice Vega. :bow:
Welcome to our forum. wEc1
May I suggest you post a bit about yourself in the Welcome Board.
Best Regards
You did a very nice job on that engine.
Now that's a good idea of putting the pushrod adjustments on the rockers,
I've been putting them on the pushrods themselves, and it's very inconvenient to adjust that way.
Good workmanship...
Thanks.
-MB
for those who are looking for plans for the vega go to the yahoo group web site miniature internal combustion engines hope it helps many.
regards wayne
