RR17,
Bob's version of lapping.
1. If your lap is made to the bore size then the bore will be oversize when its lapped. I try to machine the bore to 0.001" undersize and the last thou is removed by the lapping process. The lap must be small enough to accommodate this plus some lapping compound plus working room - say 1/64". The lap to cyl length ratio should be a minimum 3:1, i.e. the lap should be 3 times longer than the cylinder.
2. Ideally the lap should be of a softer material than the object being lapped - definitely NOT harder.
3. cyl 0.001" under piston 0.001" over.
4. Most definitely - I do this by mating them with tallow after the piston has entered the bore about 80% of the way by a hand push.
It is very important that ALL traces of lapping compund are removed before attempting to mate the parts.
Hope this helps. ??? ???
Best Regards
