Sorry to bring back memories of your local house-of-pain, but I was wondering if anyone remembers the type of dentist drill that worked off a system of pivoted arms with pulleys at the joints giving the handpiece almost total degrees of freedom. I would want to make a simpler, heavier system with only 2 arms, so I could mount the motor on the lathe bench to drive a toolpost cutting frame first (for slitting saws and external grinding) then later a toolpost spindle (for internal grinding), and giving the cutting frame or spindle freedom of movement on the cross slide. Can someone please direct me to a diagram of that type of dental drill with detail of the arms, pivots and pulleys. Last time I saw one I must have been about 10 and didnt take in the details.
What kind of power and rpm (at the spindle) should I be looking at if I want to drive a slitting saw of 32mm diameter, 80 teeth, 0.3mm wide or 32mm x 64 teeth x 0.6mm? Will round 8mm belting be up to the torque required?
Thanx guys,
Ant
Thanx guys,
Ant
