- Oct 29, 2011
- 287
- 2
Hi folks
Newbie here, but I'm getting into machining casting kits (Stuart, PM Research etc) so you'll probably see more of me.
I obtained a Stuart No. 4 casting kit on eBay, with a photocopy of the plans (dated 1953). I've no idea if the kit matches the date of the plans; I suspect it's more recent.
What confuses me is the crosshead/piston rod. The plans show the crosshead and piston rod as what looks like a single part (part 20), possibly turned from a casting. However, my kit didn't include a casting for this, and http://www.stuartmodels.com/part_cat.cfm?cat=18 doesn't list one. Also confusing is that http://www.stuartmodels.com/inprod_det.cfm/section/casting/mod_id/65 lists the crosshead as a gunmetal casting.
If I were to make the crosshead from stock, I guess I'd want to thread the end of the piston rod, and use a lock nut there too? It looks like that locknut might have to be recessed into the crosshead though.
Also, if I were to make the crosshead from bar stock, what would the best material be? It's going to be sliding against the cast iron of the standard.
Thanks
Simon
Thanks
Simon
