- Jul 3, 2010
- 278
- 10
Hi guys!
It has been a while since I have been here, sorry for that. I started flying RC helicopters and it took most of my time lately. More complicated than expected and also I am not 18 anymore. Its all about programming the remote control operation in your brain. As soon as you have the helicopter in the air and you need to think about the stick movement you are too late, it should be a second nature.
I started to miss my machining and also the weather is too cold to fly. I thought about to pick up my Stanley steamer car but I never have build a steam engine in my live. To start a 2 cylinder feels a bit risky to me, so I purchased a Stuart 10H kit. This is proven design, affordable and will have all the aspects I want to learn about a steam engine. This will be not a quick story, the goal is not to set a new machining record, but to learn, share and have fun in the shop! I will put more photos than text, normally a photo explains more then 1000 words. Everybody please feel free to ask and comment (positively as well as critically!)
Here we go. Started with the base, quite simple, just face mill the top and bottom sides.
Last operation on this part is to drill the 2 holes (3mm). I used the center holes available in the casting, they were quite in the middle.
Next casting to attack is the sole plate. I put it straight in the vise (leveled it visually) to face the bottom.
Now the bottom is flat I can use this side a reference for all the other operations on this part. Time to drill some holes (2.5 mm)
With the shown hole I noticed a very hard part in the casting. I was able to get a 2mm hole, the 2.5mm drill would not go through, casting skin is too hard! I ended up drilling it increments of 0.1mm and that worked. Hope this is the only hard spot in the casting......
To copy the holes into the machined base I clamped the soleplate to the based and center drilled with 2.5mm drill.
Used the center drill marks in the base to drill through with 2.1mm drill, tapped all the 4 holes 7BA and mounted the tread bars.
Luckily the soleplate fitted well on the base....
Next will be the bearings.
Thanks for watching and have fun in the shop!
Jeroen
![DSC_0733.jpg](https://proxy.imagearchive.com/bbd/bbd2f4f73fa72b5d06ac43cc9ec79518.jpg)
![DSC_0734.jpg](https://proxy.imagearchive.com/181/181ca56135392f21b15c79aeb63b317f.jpg)
![DSC_0735.jpg](https://proxy.imagearchive.com/50b/50b91237fb1dd0c7e77f0d9685840958.jpg)
![DSC_0736.jpg](https://proxy.imagearchive.com/8a9/8a9f531ffd55737bdbc8a226698ba6c8.jpg)
![DSC_0737.jpg](https://proxy.imagearchive.com/d88/d88fb259e393abc592e834bff941cf72.jpg)
![DSC_0738.jpg](https://proxy.imagearchive.com/abf/abf6fbedac6842b508d7fa1139f17a7a.jpg)
![DSC_0739.jpg](https://proxy.imagearchive.com/230/230f8e1c669ad6edd28cb94169df155b.jpg)
![DSC_0740.jpg](https://proxy.imagearchive.com/fa2/fa26b29df954079aeca002633146b7e0.jpg)
![DSC_0742.jpg](https://proxy.imagearchive.com/6ba/6bae3c1a19d8d8e5e69a8d3a74e225ef.jpg)
![DSC_0745.jpg](https://proxy.imagearchive.com/bda/bda3457223afd0874c733af57f9db5dc.jpg)
![DSC_0746.jpg](https://proxy.imagearchive.com/d25/d257484991fd2da83978f4bde8176427.jpg)
Jeroen
