black85vette
- Jan 18, 2009
- 1,084
- 24
Made some improvements to the shop space. This all started when I bought an 18,000 BTU air conditioner pretty cheap. So, I HAD to have a wall to mount it on. Then things just went from there. Decided to enclose just my work space in the garage. About 90 sq ft for the mill, lathe, drill and bench. Everything else is out in the garage.
Here is the enclosure I built with the air unit mounted
Inside the shop. Put the 220 volt outlet just under the air conditioner. Cant really see it but the main power panel for the house is just to the left side of the lathe.
I made a flange to mount an air fitting on the wall. Air compressor sits outside next to the wall and connects with a short hose. Also put another quad outlet on that wall. You can never have too many.
The door to the shop was constrained by the drop down stairs to the attic space. I just worked around it.
Mill and drill on the bench space
In the corner is room for the vacuum and some additional bench space. At the top is an electric heater for the area.
Just finished the walls yesterday.
