Side Shaft Hit & Miss Solenoid Motor Number 3!
Coilmotorworks
Active Member
Upper Midwest USA
Yes, that is right. This is the third one of its kind. This one features a different style governor, instead of a wedge it uses a dropping collar, the switch is a direct press instead of leaf spring and uses a 6VDC commercial coil, the same as the first one. The gears are plastic. This motor took about a month to build.
Forrest A
