Tin Falcon
- Jul 9, 2007
- 7,207
- 788
As a home machinist the rules we follow are up to us they are not likely posted and not even written on paper. They are in our mind or heart . There are no stupid rules because it is your shop and do things your way. But we need to work safe if we are always getting hurt the hobby is no longer fun. so here is a written set of rules to follow or use as a guide . Again it is your shop you work in so pick what works for you but above all work safely.
Machine Shop Safety
Safety Glasses
EVERYONE MUST WEAR SAFETY GLASSES IN THE SHOP AT ALL TIMES.
Even when you're not working on a machine, you must wear safety glasses Even hand tools can make chips.
Wear Hearing Protection as required (If you have to raise your voice to speak to someone 3 ft away hearing protection should be worn).
Clothes and Hair
Check your clothes and hair before you walk into the shop.
IF YOU HAVE LONG HAIR OR A LONG BEARD, TIE IT UP.
If your hair is caught in spinning machinery, it will be pulled out if you're lucky. If you're unlucky, you will be pulled into the machine.
NO LOOSE CLOTHING.
Roll up sleeves. Neckties, scarves, loose sleeves, etc. are prohibited
NO GLOVES ON OR AROUND MACHINERY
REMOVE ALL JEWELRY
WEAR APPROPRIATE SHOES
No open toed sandals. Wear shoes that give a sure footing. If you are working with heavy objects, steel toes are recommended.
Safe Conduct in the Shop
Be aware of what's going on around you. Pets and family members may move things or enter the shop at any time.
Keep Machinery Area Clear. Do not put unneeded items on or around machines.
Keep Walkways Clear. Remove tripping hazards, and clean spills up immediately.
Concentrate on what you're doing.
Don't hurry. If you catch yourself rushing, slow down.
Don't rush speeds and feeds. You'll end up damaging your part, the tools, and maybe the machine or yourself
Listen to the machine. If something doesn't sound right, turn the machine off.
Don't attempt to measure a part that's moving.
Don't let someone else talk you into doing something dangerous.
If someone speaks to you while youre running a machine, keep your eyes on your machine and not on the person.
If you get tired or are feeling ill, turn machine off, take a break.
Machining
IF YOU DON'T KNOW HOW TO DO SOMETHING, ASK read find out.
BEFORE YOU START THE MACHINE:
Read the Manual
Study the machine. Know which parts move, which are stationary, and which are sharp.
Double check that your work piece and tool are securely held.
Remove chuck keys and wrenches.
Use no rags on machinery while it is in operation and/or in use.
Do not place any tools or other metal objects on machine ways.
Do not clear chips from machines with bare hands. Use pliers or a chip brush.
DO NOT LEAVE MACHINES RUNNING UNATTENDED!
CLEAN UP MACHINES AFTER YOU USE THEM!
A dirty machine is unsafe and uncomfortable to work on. Do NOT use compressed air to blow machines clean! This endangers people's eyes and can force dirt into machine bearings.
TURN POWER OFF TO MACHINE WHILE CLEANING/MAINTAINING!
When working alone keep a clear path to the telephone and have it as close at hand as practical and safe.
Do Not operate Machinery after or while consuming Alcoholic beverages.
Cease hot operations 30 minutes prior leaving the shop area unattended. ie welding, brazing, heavy grinding, smoking etc.
Store flammables in a safe place
Keep a fire extinguisher handy inspect regularly.
Chemical safety
Keep all solvents cutting oils and other chemicals in proper storage containers.
keep all chemicals in clearly marked containers.
Keep food and chemicals separated.
Do not use food ovens for chemicals or chemical ovens for food.
( If you use an old oven from the kitchen for chemicals it is now a chemical oven!
Wash hands before eating drinking smoking or using the bathroom (and after).
Grinders :Wear double eye protection.
Keep all guards in place
Keep tool rest adjusted 1/8 " from wheel
DO NOT grind aluminum or brass
DO NOT Grind on side of wheel.
Do not stand in line with spinning wheel
Wear a dust respirator Metal and Wheel dust can be harmful if inhaled.
First aid Kit:
Have one
Mark its location
Inspect /restock regularly
Place machines and lighting on separate circuits if possible
if a machine trips a breaker you will not be left in the dark.
It is your shop you are responsible for your safety.
Tin
Machine Shop Safety
Safety Glasses
Clothes and Hair
NO LOOSE CLOTHING.
REMOVE ALL JEWELRY
Machining
Read the Manual
Chemical safety
First aid Kit:
Have one
Mark its location
Tin
