Gday , I have a Oscar Ehrilch lathe and I'm looking for a Brass plaque with the screwcutting gears ( feeds and speeds ) it goes on the front of the left leg , I'm in Qld Australia , any help would be appreciated thank you , Spider
You can become a Supporting Member which comes with a decal or just click here to donate.
I found this on Lathes UK site, there's quite a lot of information on Ehrlich lathes i don't know if it's the same as yoursGday , I have a Oscar Ehrilch lathe and I'm looking for a Brass plaque with the screwcutting gears ( feeds and speeds ) it goes on the front of the left leg , I'm in Qld Australia , any help would be appreciated thank you , Spider
Yes that's it , thank youI found this on Lathes UK site, there's quite a lot of information on Ehrlich lathes i don't know if it's the same as yours
edward tart
You find other brands with the same lead screw and manual change gears . Quick change is harder as needs to match your lathe.Gday , I have a Oscar Ehrilch lathe and I'm looking for a Brass plaque with the screwcutting gears ( feeds and speeds ) it goes on the front of the left leg , I'm in Qld Australia , any help would be appreciated thank you , Spider
Thank youYou find other brands with the same lead screw and manual change gears . Quick change is harder as needs to match your lathe.
A good photo you your own by screen printing and copper plating.
Register today and take advantage of membership benefits.
