R-14 Help
Discussion in 'General Engine Discussion' started by jgarrett, Aug 24, 2007.
  1. Aug 24, 2007 #1
    jgarrett
    jgarrett
    jgarrett
    Well-Known Member HMEM Supporter
    Aug 22, 2007
    193
    1
    Ernie, I have a question about drawing a line in degrees. I can do pretty well with 2-D stuff and I had to reload about 6 months ago and if I remember correctly in the status bar where it shows your x,y position it used to show degrees also. I have not been able to get that back. If I need to draw a line a certain degree now I have to guess at it , dimention it and then make corrections to get it right. I am pretty sure it is a setting but I cannot find it. Can you help me out on this???
    Thanks,
    Julian
  2. Aug 26, 2007 #2
    ernie7
    ernie7
    ernie7
    Jul 15, 2007
    5
    0
    Drawing a line at any angle is easy:
    Enter the line command, then select the start point of the line, then follow this as an example: @2<45
    This means from the last point (@) draw a line 2 long at an angle (<) of 45 degrees. Note the degrees are always measured from the horizontal (0). Hope this helps.
  3. Aug 26, 2007 #3
    jgarrett
    jgarrett
    jgarrett
    Aug 22, 2007
    193
    1
    Ernie, Thanks, for the reminder. I guess I am already doing that. I do that all of time. Have not had to draw any angles in a long time( other than 0,90,180,270) so just forgot I could draw anything in between DUH!!! I guess I was just looking for the angle in the status bar.
    Thanks,
    Julian
Draft saved Draft deleted
Share This Page
Group Builder
