Rock', not knowing the size of your lathe I can only suggest a couple of things as far as shipping goes. Shop around for prices on freight charges etc. Find the one place that fits YOUR schedule and requirements and then ask them for references and follow them up. This will eliminate the Billy Bob and his nephew team from taking you to the cleaners by hauling it in their pickup truck. There are really two ways to ship large machines and both methods do require some time spent in preparation. Firstly, the machine should be securely mounted to a pallet with lag bolts THROUGH the supports and not merely screwed into the wood (there is always the possibility of the pulling out if you do not go through the piece and back up the nuts with large diameter washers). Next up is to remove all levers and handles and knobs and chucks that could get stepped on, caught, banged into etc, etc. Place these components in a sturdy separate box for shipping. Now, the two different methods are to either wrap the machine up in plastic strecth wrap once it is secured to the pallet and ship it that way (not recommended) or build a crate/box that will encase the pallet with the machine firmly attached to it. This method *should* prevent anything drastic from happening short of the crate falling off the truck or being dropped. If you are not able to or do not have the time for such carpentry, some of the better freight offices will do so for a fee. These guidelines are really meant for larger machines but the same principles apply to smaller types and are advisable in any case. Keep the separate box of all of the parts and tooling together in the same crate as the machine if possible, this will prevent them from getting lost/separated/stolen in transit. You would truly be amazed of the way that freight is handled, not like your Mother's fine china, that is for certain, so any precautions and safegaurds that you can do up front will increase the chances of the machine getting to it's destination unscathed. Best of luck in your move and we are all looking forward to seeing your E-Z build.
BC1
Jim
