New here
Cornnatron
Netherlands
Hello there,
Im new here and am in the progress of setting up a very small but capable home machine shop,
Got a lathe and a drillpress and a small homebuilt cnc routertable capable of machining aluminium ,
And was interested to see if there are some plans to make a small engine with those tools.
Im also looking to figure out the software for my small rotary table which i want to drive with a arduino and a stepper and seeing i dont want to invent the wheel i thought ill go on here and ask what other people would suggest seeing that aint a new concept,
The rotary table is to mount on the lathe spindle and be capable of clocking the spindel and has a 1:90 gearing. But that is already sorted.
Cheers corn
GreenTwin
Moderator
Staff member
Moderator
HMEM Supporting Member
Global Moderator
MidSouth
I am not sure if this qualifies for a "small engine", but this is one of my dad's designs that I created 2D drawings for.
  • No-21-Oscillator-Rev-08.pdf
Cornnatron
Netherlands
Thanks for that , but ill put some search to a metric one seeing im in europe and metric is the standard here
SmithDoor
Staff member
Global Moderator
Clovis Ca
Welcome to the group
Hello there,
Cheers corn
Bentwings
Minnesota
Welcome tengineso the group. There are lots of model engines plans and kits available . Are you looking at steamers or ic engines? If you really want to test your skills hogs on has a very complete set of plans for up to 18 cyl radial engines. Many of these have been built so it’s a well proven design he is a great guy to talk to actually the radials are pretty straight forward. Just one heck of a lot of parts my plan set has to weigh 6-7 pounds he even offers a simple rear cover casting .
byron
animal12
Cornnatron there's a few Arduino Rotary table setup's here on the forum . Here's a few to get you started , I'm sure there's more . Let us know which way youi go on this , It's always nice to see other folk's version .
animal
Cornnatron
Netherlands
A fellow named Julius de Waal created a metric version of my No.21 engine drawings, and those drawings can be found here:
(for those who use the metric system)
Cheers for that ill surely have a look at those.
byron
At first ill look at steamers.
Cause they are a bit more simple and i am still just a starter in this stuff , only got a lathe since 2 months a cq6133. And never turned any metal except twistdrills and nuts and bolts and screws before that.
and im all selftought through utube.
But im getting the hang of it though plenty still to learn .
animal
Cheers for those ill certenly have a look at those.
Michel ROBIN
Beausemblant (26240) - FRANCE
Hello everyone from France.
These are metric plans of a very small steam engine (7mm bore x 10mm stroke).
Small but complex depending on the model choice, single or many cylinders and 2 directions of rotation.
You can adapt the size of plan to your machines and with available materials by applying a coefficient to all dimensions.
Cordially.
Michel
  • Mini_O_7x10.pdf
Bentwings
Minnesota
Hello there,
Cheers corn
Are you going to drive the spindle with the rotary or mount the rotary on the spindle or lathe chuck?
Byron
Cornnatron
Netherlands
Cordially.
Michel
Thanks for the plans a bit to complex jet but will keep for when im a bid more advanced.
Byron
Gonna drive the spindle with it thats the easyest option , seeing the center of the rotary aint in the center of the rear housing .
Second my lathe aint got a spindle lock yet.
So i would have to chuck it up in the 4jaw and create a spinle lock if i was to mount it in the chuck.
