Boot was overwhelmed by the prospect of running a DOS program so I offered to run the case for him.
As you can see from the output, the hole plates are chosen to provide all the divisions through fifty; beyond that some are possible but many require higher number hole plates which the program specifies.
Alternatively, those higher number divisions can be done by using my ROTARY program.
Turns & holes/plate for dividing head with worm gear ratio = 72:1
Available hole plates =
16, 17, 19, 20, 23, 25, 27, 29, 31, 33, 35, 37, 39, 41, 43, 45, 47, 49,
2 => 36 & 0
3 => 24 & 0
4 => 18 & 0
5 => 14 & 8/20 or 10/25 or 14/35 or 18/45
6 => 12 & 0
7 => 10 & 10/35 or 14/49
8 => 9 & 0
9 => 8 & 0
10 => 7 & 4/20 or 5/25 or 7/35 or 9/45
11 => 6 & 18/33
12 => 6 & 0
13 => 5 & 21/39
14 => 5 & 5/35 or 7/49
15 => 4 & 16/20 or 20/25 or 28/35 or 36/45
16 => 4 & 8/16 or 10/20
17 => 4 & 4/17
18 => 4 & 0
19 => 3 & 15/19
20 => 3 & 12/20 or 15/25 or 21/35 or 27/45
21 => 3 & 15/35 or 21/49
22 => 3 & 9/33
23 => 3 & 3/23
24 => 3 & 0
25 => 2 & 22/25
26 => 2 & 30/39
27 => 2 & 18/27 or 22/33 or 26/39 or 30/45
28 => 2 & 20/35 or 28/49
29 => 2 & 14/29
30 => 2 & 8/20 or 10/25 or 14/35 or 18/45
31 => 2 & 10/31
32 => 2 & 4/16 or 5/20
33 => 2 & 6/33
34 => 2 & 2/17
35 => 2 & 2/35
36 => 2 & 0
37 => 1 & 35/37
38 => 1 & 17/19
39 => 1 & 33/39
40 => 1 & 16/20 or 20/25 or 28/35 or 36/45
41 => 1 & 31/41
42 => 1 & 25/35 or 35/49
43 => 1 & 29/43
44 => 1 & 21/33
45 => 1 & 12/20 or 15/25 or 21/35 or 27/45
46 => 1 & 13/23
47 => 1 & 25/47
48 => 1 & 8/16 or 10/20
49 => 1 & 23/49
50 => 1 & 11/25
51 => 1 & 7/17
52 => 1 & 15/39
53 => a plate with an integer multiple of 53 holes is required
54 => 1 & 9/27 or 11/33 or 13/39 or 15/45
55 => a plate with an integer multiple of 55 holes is required
56 => 1 & 10/35 or 14/49
57 => 1 & 5/19
58 => 1 & 7/29
59 => a plate with an integer multiple of 59 holes is required
60 => 1 & 4/20 or 5/25 or 7/35 or 9/45
61 => a plate with an integer multiple of 61 holes is required
62 => 1 & 5/31
63 => 1 & 5/35 or 7/49
64 => 1 & 2/16
65 => a plate with an integer multiple of 65 holes is required
66 => 1 & 3/33
67 => a plate with an integer multiple of 67 holes is required
68 => 1 & 1/17
69 => 1 & 1/23
70 => 1 & 1/35
71 => a plate with an integer multiple of 71 holes is required
72 => 1 & 0
73 => a plate with an integer multiple of 73 holes is required
74 => 0 & 36/37
75 => 0 & 24/25
76 => 0 & 18/19
77 => a plate with an integer multiple of 77 holes is required
78 => 0 & 36/39
79 => a plate with an integer multiple of 79 holes is required
80 => 0 & 18/20
81 => 0 & 24/27 or 40/45
82 => 0 & 36/41
83 => a plate with an integer multiple of 83 holes is required
84 => 0 & 30/35 or 42/49
85 => a plate with an integer multiple of 85 holes is required
86 => 0 & 36/43
87 => 0 & 24/29
88 => 0 & 27/33
89 => a plate with an integer multiple of 89 holes is required
90 => 0 & 16/20 or 20/25 or 28/35 or 36/45
91 => a plate with an integer multiple of 91 holes is required
92 => 0 & 18/23
93 => 0 & 24/31
94 => 0 & 36/47
95 => a plate with an integer multiple of 95 holes is required
96 => 0 & 12/16 or 15/20
97 => a plate with an integer multiple of 97 holes is required
98 => 0 & 36/49
99 => 0 & 24/33
100 => 0 & 18/25
