- Apr 3, 2017
- 61
- 23
Hi All,
after finishing the two Boll Aero 18s and a workshop covered in castor oil and several scars and cuts on my fingers, it's finally time to get going on my next engine. After a few recommendations I have decided to go for the Nalon Viper 2.5 using plans from the Motor Boys crew at modelenginenews.org.
Im spending a bit pf time up front modelling the plans out in CAD and doing the imperial to metric conversions there to make sure everything checks out and just 'getting my head around' making the parts and how things should fit. This engine is actually way more sophisticated than anything I've attempted before so I'm slightly daunted and excited at the same time. Looking forward to making some swarf and at the same time realistic that my scrap bucket might also see some additions.
They say the journey of a 1000 miles begins with a single step well I guess that is the purchase of some bearings!
Anyway the question I have for some people out there far more knowledgable in such matters than I am is per the picture below. Do I need to provide a bit of relief to ensure that the inner ring of the bearings doesn't rub on the crank web or the bearing seat or can I implement the plans exactly as drawn. I have crudely scribbled the areas on the plan where I think there may be interference below and would really appreciate a steer on whether this could cause issues/needs a bit of machining so nothing touches the inner ring. I have studied a bunch of plans and photos and it **looks** like there is no issue and the bearing seats can just be flat but wanted to ask the forum to see is there is a 'proper way' of doing this.
Also in the axial dimension, I assume the front split cone rides on the inner ring and pulls the inner rings and crank shaft tight against each other so they rotate together and cant slip on the shaft.
Thanks all in advance.
Patrick
Patrick
