Well I thought maybe some of you guys might like to check this out. Its a manual mill I made several years ago.
I decided a couple of months ago to give it a major overhaul to improve precision and add drilling capability to it.
So far I have
Replaced the table cast iron nuts with Acetal nuts that are adjustable for backlash.
Added DRO to X and Y axis
Added bellow to the front part of the y axis
Completed all the milling for the new quill housing, just need to drill and tap for some bearing covers and then press the spindle into its new home. The new quill is needed as currently if I need to drill I have to crank the head up and down.
The quill is by far one of the hardest things I have done, with the y axis DRO being the second hardest thing.
Once all the hardware mods are done it will be a fresh paint and the bench is getting fixed up too, more bracing and leveling.
More to come....
So far I have
More to come....
