My first I.C. engine, a variation on the theme of Webster
LUC---GET OFF MY CASE!!! That was not a negative post. That was information given freely to someone who may not have known it. I am getting very tired of you Luc, and of your attitude.---Brian
To address a few earlier points, here are pictures of the "mock-up" which is as far as I got in time for Christmas:
I did attempt a "balanced" crank to offset the rod weight and to attempt the keep the engine from walking around too much when running. Got the carb adapter done and installed for an OS #10G model engine carb. Still needs the cam finished, the top of the water hopper, a lot of miscellaneous spacers/bushings/hardware, the points I got didn't include the isolator that the wires mount to so I have to make something for that, and a fuel tank.
JLeatherman !
That is one sweet looking Webster. Nice clean design . . . . Loving it.
If I could respectfully make one point.
In your mock-up. . . . . Where’s that beautiful FLYWHEEL!stickpoke
Hey did you take your AGRESSIVE PILL AGAIN
BTW I am entitle to my opinion like evryone else
this is not
BRMEM
but HMEM
cheers
and if their is something yuou don't like about my opinion
don't be mother Theresa send me a PM
Although I found some of Brian's earlier comments on this thread a bit harsh and one-sided I thought the most recent post about roller cams to be informative. In fact, upon further reflection I think my mistake in cam duration will help me because I didn't account for how the roller would impact cam timing. The roller should, I believe, lengthen cam timing slightly so the fact that I inadvertently shortened it when machining may well be a wash in the end.
I intend to continue building it as I want to, and look forward to the results. Anything that doesn't work as I'd hoped will just be time saved on a future engine.
JLeatherman !
It's not pinned in place until i get the came done, and without it being pinned it slides back and forth into the cutout I made in the baseplate. I don't want it getting dinged up. Hopefully soon it will be installed for good!
It's been too cold to spend too much time in the shop at once, but I've gotten a bit more done. I made the valve spring retainers, lapped the valves, and installed the valves and springs on the engine. I made a change to the prints (again) in the spring retainers. I counterbored the top side of each retainer so it fits over the pin the goes through the valve stem. This will keep the pin in place, and it wasn't hardly any extra work.
I also finished tapping the rocker arm for the adjuster and installed it, and made a spacer to get the rocker arm directly under the valve.
Lastly I made the top cover for my water hopper. It's not screwed down because I didn't have the correct length screws, but everything looks like it should line up.
Now that the rocker arm is in place I can make spacers for the cam and flywheel and get them installed.
It is very important to have the correct spring on the rocker arm to keep it in contact with the cam. I used a piece of recoil spring from a weed-eater.
Morning JLeatherman
It’s definitely been a weird winter, you guys out east both sides of the 49 parallel are having a bad one. Our normal daytime highs for this time of year should be around -12c with 2 or 3 feet of snow pack. This year it’s more like 0 to +6c and until the 20cm we got last week you could see the stubble sticking up through the snow in the fields.
This Webster is looking sweet. Love the hopper and cover. Your valve block looks great. One thing that I read over and over before I built my Webster was people having trouble starting IC engines because the valves where leaking. What I did so I could test them was make up a block from scrap so that I could connect it to my compressor. I thought I had them seating but with 5 or 10 lbs of air going into the port that goes to the cylinder the whole thing leaked like a window screen.
On my build I couldn’t use a flat leaf spring like the plans called for because of the flare on the bottom of my frames. I’d seen the way Chuck Fellows used trimmed down angle for the frame of his “Bessemer Hot Tube Oil Field Engine” and liked the look so much I just wanted to go with it not thinking of the spring.
What I ended up doing was using a trigger spring on the rocker arm. You’ve got straight sides so the flat spring it no problem and like Brian said any spring from a small recoil start will work. If you have a small engine repair shop near you ask if they’ve got a broken one you have. It’s surprising how many people are willing to help you out (talk to the oldest guy at the counter ;D) once they know what you’re doing. Oh and put some pictures on your phone for show and tell. I think the only critical thing is “It is very important to have a spring on the rocker arm to keep it in contact with the cam.” The engine is coming along great and I can’t wait for that “smelling burning Coleman” and “giggling like a school girl” moment.Thm:
Your spring is a very good idea. Bought flat spring from TokyuHands 2013. Was scrounging in Singapore to no avail but happened to holiday in Tokyo and found flat spring staring at me while shopping.
I'm still here and still working on the Webster when I have a chance. I had to modify a few small details in my plans. The cam roller retainer, which is basically just a small flanged nut, was supposed to have #4-40 threads inside but the walls were too thin and it kept breaking during threading. It now has #3-48 threads and works fine. I've worked on some of the fiddly parts, like the proper spacers for the rocker arm and cam, etc. Doesn't look like much more has happened, but the flywheel is on and some parts have been loctited in place hopefully to remain.
Here's a good shot of the overall engine to date:
And here's a shot of the finished roller-rocker:
I made a crank that uses a threaded crank-pin, which it now occurs to me should have been LH thread. I'm going to have to make the engine run backwards so that the forces on the crank make the pin tighter as opposed to unscrewing as it runs. Shouldn't be a big change. I'm up to the step where I drill and pin the flywheel in place, just giving myself a little time to be sure everything else is good first. Then I need to start thinking about securing it to a base and working on an ignition and fuel system.
Leatherman what can I say . . . but . . . but . . . DAMN that’s a good looking engine.
