• If you have bought, sold or gained information from our Classifieds, please donate to HomeModelEngineMachinist and give back.
    You can become a Supporting Member which comes with a decal or just click here to donate.
Misc. Tooling For Sale
sparky961
I recently acquired some tooling and have had a chance to sort through most of it. Up for offer is a bunch of stuff I already have plenty of, or won't likely ever need.
If you see something you like, make a reasonable offer and it won't be refused.
Items are in Ontario, Canada - about 2 hours NW of Toronto.
Num Desc Cond
1 1" spot/stubby drill, HSS, 6-1/2" length very good
2 25/32" straight reamer, HSS+carbide, 9-1/2" length needs cleanup
3 7/8 2-flute end mill (7/8" shank), HSS, 3-3/4" length some pitting on shank, cutting edges ok
4 #7 x 1/4" centre drill, HSS (Black oxide), Butterfield minor wear
5 SR 20-10.0mm collet minor wear
6 #7 x 1/4" centre drill, HSS, Poland Appears unused
7 1" countersink, carbide with steel shank Reground, appears usable
8 5/8" shank Borite boring bar, carbide tipped, 3-1/4" length minor wear
9 #7 x 1/4" centre drill, solid carbide, GARR one end minor damage, other end minor wear
10 #7 x 1/4" centre drill, HSS, PTD USA minor wear
11 1/2" 4-flute core drill, HSS, PTD USA surface rust and some pitting, but should clean up ok
12 (3/8)x13/32x19/32 Counterbore, HSS, 1/2" shank, 6" length like new
13 11.31mm (0.446") solid carbide end mill, 3" length 2 flutes damaged at corners, otherwise like new
14 3/16" drill with Morse taper #1 shank, 5-3/4" length minor wear, very minor surface rust
15 13/64" straight reamer, HSS, USA like new
16 3/8" ballnose end mill, solid carbide, 4-flute minor damage to 2 flutes
17 13/64 straight reamer, HSS, Poland Like new
18 1" 3-flute end mill (1" shank), HSS needs re-sharpened
19 #6 centre drill, HSS, Osborne one end needs re-sharpened
20 573g (20.2 oz) various damaged solid carbide tooling
Thanks..
-Sparky
