Mini Mill Sieg X2 to CNC and other modifications
hello, i have a lathe as the same the yours,but it is short of a part,you can see as the picture. Do
you have the part? And could you tell me how many the toothlike part of the part are. And do you have
the illustration of the lathe? thank you .
Poiuy,
I just saw the pictures, now I understand your question.
The gear showed by the arrow is Z = 40 and mod = 2.
All other gears following this gear are mod 1.5.
What's wrong with your lathe?, as I see in the photos, all the gears are in place. You only need to adjust the apron loosening the bolt located behind the gear indicated by the arrow and upload it to fit the previous gear (with mod 2).
This weekend I will take some pictures.
German
the gear you point at rides on a shaft that is attached to a flat pivot bar. Near the bottom of that pivot bar should be a allen head screw that you loosen and then push the gear so that it meshes with the one above it.
Yes, this Allen screw (or hexagonal bolt) is for adjust the the flat pivot bar.
I have allen bolt in this place, but in some position of the bar is difficult to access to the bolt.
These are the pictures of the gear system in my Erten
The apron:
Gears adjusted :
This is an improvement with a differential reduction system, in order to obtain low cutting advance.
