I have been building one of these Lamina Flow engines for two months using only the information from this site, and others on the web. No formal plans. I got it together last week, and can not get it to run. Rather than putting it on a shelf I am determined to get it working, and would appreciate any information from those who have gotten theirs to run. It has a 1" stroke and .912 bore with a graphite piston, and I am using a .885 x 5.750 Pyrex test tube with SS Regenerator material about 2/3 volume of the tube. I have made several flow restrictors with openings from .125 thru .450, and none seem to make any difference. I installed a P M Research bronze 3.5 OD flywheel, but felt that it might be too light so I installed with it another one one on the outbound end of the crankshaft with no change in performance using either one or both of them. The engine turns very freely on bearings with the test tube removed, and has good compression with it attached. I am using a small alcohol burner to heat the tube at the end of the regenerator. I tried to calculate the compression ratio, and came up with 1.056 to 1 with no regenerator material installed. I have tried to increase the ratio by putting an aluminum plug in the far end of the test tube, but still no improvement. Again any direction would be appreciated, Thanks,
ART
ART
