Gear cutter holder
Discussion in 'Tools' started by wesley, Dec 16, 2017.
  1. Dec 16, 2017 #1
    wesley
    wesley
    wesley
    Aug 2, 2009
    66
    13
    Hi all need to get a set of Involute gear cutters ,the ones l am looking at have a 22mm bore an key way slot.
    What l need is a kind person out there to send me some diamensions of a tool holder ie from where the taper starts to the end ,so need thread length/nut /spacers and how long is the key,sorry to be a pain , but have to make my own as the mill has a NT 41 taper and if you can find one then l would have to save for the next ten years for it ,so have to go the shop made way,hope this makes sence.
    wes:hDe:
  2. Dec 16, 2017 #2
    BaronJ
    BaronJ
    BaronJ
    Grumpy Old Git.
    Dec 6, 2013
    632
    230
    Hi Wesley,
    I'm not sure that I understand what you are asking ! The gear cutters have a parallel bore, and I assume that you have some method of holding a straight shank. So it becomes a simple turning job to make a tool holder and a suitable slot drill for making the keyway, though I must admit that I don't use it, I've not had a cutter slip whilst cutting.
  3. Dec 16, 2017 #3
    restore49
    restore49
    restore49
    Active Member
    Nov 5, 2017
    26
    9
    There is a Web site that lists the dimensions for all the different tapers - hope you have a taper attachment . The cutter end is simply a shaft with a nut and a pin driven in to engage the slot in the cutter.
  4. Dec 16, 2017 #4
    DJP
    DJP
    DJP
    Dec 7, 2012
    272
    80
    This sounds like an horizontal mill cutter holder. They should be available in various tapers. My old Burke mill had a Browne and Sharp taper for example. If you visit a small machine shop I'll bet they have some in the junk bin.
  5. Dec 16, 2017 #5
    bazmak
    bazmak
    bazmak
    BAZMAK
    Dec 12, 2012
    1,967
    1,105
    A little more info would be good If its for a horizontal mill then the cutter with 22mm bore will be too small for the arbor shaft ??
    I bought an R8 face cutter for my mill and deailed an adaptor to clamp and keyway as the arbor had a 22mm spigot.2 tools for the price of 0ne.If you intend to make the whole arbor,dont you have an existing one to measure ??
    BaronJ likes this.
  6. Dec 17, 2017 #6
    goldstar31
    goldstar31
    goldstar31
    Feb 20, 2010
    1,653
    384
    I'm in agreement with Barry because MY quite large selection of gear cutters have a 1" bore.
    If I'm right, one is stamped VAP which probably suggests a modestly important firm called Vickers Armstrong's, Scotswood or Elswick I know not.
    Supplier ESC Ltd- no less!
    But Heigh Ho, eh?
    Norm
    BaronJ likes this.
  7. Dec 17, 2017 #7
    xpylonracer
    xpylonracer
    xpylonracer
    Dec 23, 2010
    218
    51
    Some European made cutters for Emco were MOD type with 16mm bore, this applies to cutters up to 1.5 MOD.
    xpylonracer
  8. Dec 17, 2017 #8
    ThomasSK
    ThomasSK
    ThomasSK
    Active Member
    Aug 9, 2014
    32
    3
    22mm is common for module (metric) cutters in the range 1-3M. DP cutter (Imperial) have different bore sizes, altough some comming from china has metric bores. Quite nice for us who don't do much imperial, and don't want to stock a set of holders for those as well.
    16mm bore cutters are used in the range 0.5-0.8M. Proxxon in germany has a simple holder (par no 24 425) for those fairly cheap, that can be replicated fairly easy. A picture of it can be found a bit down on this page: http://micro-machine-shop.com/gears.htm
    It easy to make a holder like the proxxon, or you can use a appropriate shell mill holder, by modifiying one of the driving dogs, and making a spacer to go on the end to hold it in place.
    Thomas.
  9. Dec 17, 2017 #9
    Mechanicboy
    Mechanicboy
    Mechanicboy
    Jul 10, 2013
    525
    181
    Not all module gear cutter has 22 mm/16 mm diameter bore. Modul 1, Modul 0,75 and Modul 0,5 has 1" diameter bore. See this link who has 1" diameter bore in module gear cutter.
    https://www.rdgtools.co.uk/acatalog/INVOLUTE_GEAR_CUTTERS__SET_S_AND_INDIVIDUAL_.html
    Better to make own milling arbor to fit the gearcutter and fasten on ER32 collet or similiar collet.
  10. Dec 17, 2017 #10
    ThomasSK
    ThomasSK
    ThomasSK
    Active Member
    Aug 9, 2014
    32
    3
    Actualy, there is a DIN standard (EU norm) for those holes, DIN 58410 if I remember correctly. And that standard being of German orgin, I'm willing to bet there isn't a inch in it anywhere. A interesting thing is that former sovjet cutters also seems to follow this standard. Those cutters can be found on the surplus market, and are of better quality than similar priced chinese cutters.
    That said, making the arbor to fit the cutter is the only reasonable approach if one wants to get something made with them.
  11. Dec 17, 2017 #11
    Mechanicboy
    Mechanicboy
    Mechanicboy
    Jul 10, 2013
    525
    181
    I has the set of gear cutter 0,8 module with 16 mm diameter bore, made in former Soviet. Steel is of good quality.
    The standard was GOST/ГОСТ. GOST standards were originally developed by the government of the Soviet Union as part of its national standardization strategy. The word GOST (Russian: ГОСТ;) is an acronym for gosudarstvennyy standart (Russian: государственный стандарт;), which means state standard.
    They are now administered by the Euro-Asian Council for Standardization, Metrology and Certification (EASC), a standards organization chartered by the Commonwealth of Independent States.
    When i was in Ukraine, there was not inches in caliper ruler, steel ruler etc, millimetre only. When i told father-in-law about inches (he worked in Dnepr motorcycle factory/KMZ in 13 year) , he never knew about imperial measurements.
  12. Dec 17, 2017 #12
    wesley
    wesley
    wesley
    Aug 2, 2009
    66
    13
    Thanks for the replys, yes l am not very clear,my mill takes a nt41 taper tool holder,for milling l use a clarkson holder,but want to make up some holders for gear cutting and slitting saw work,l no that the gear cutters fit on a parallel shaft with a key,what l was after was the dimension of the spacers ie width and how long is the threaded bit on the shaft and the length of the complete parallel shaft that like a shop made holder, my cutters wont be here for a few weeks and was hoping to get the holder made in advance ,hope this makes more sence,and l may as well make a holder to take 1" bore cutters at the same time.As for getting hold of a tooll holder with the taper l need is not easy,did find one but the cost they wanted for it was just dam silly.
    thanks wes
  13. Dec 17, 2017 #13
    Mechanicboy
    Mechanicboy
    Mechanicboy
    Jul 10, 2013
    525
    181
    Wesley, the length of nut is not critical. I used the standard nut M8 to hold the milling cutter who has 16 mm shaft. No key on shaft. For a big cutter, the key is necessary. See at my homemade milling machine.. :)
    [ame="https://www.youtube.com/watch?v=HcG9Eoyf9aI"]https://www.youtube.com/watch?v=HcG9Eoyf9aI[/ame]
  14. Dec 17, 2017 #14
    wesley
    wesley
    wesley
    Aug 2, 2009
    66
    13
    Great machine you have made there,very good work ,can se what you mean now,will make some blanks with the taper l need then finish off when l have the cutters to hand,many thanks
    Mechanicboy likes this.
  15. Dec 17, 2017 #15
    Wizard69
    Wizard69
    Wizard69
    Mar 9, 2013
    1,095
    212
    Isn't that pretty much up to you? It isn't uncommon on such arbors to have a number of spacer rings to accomodate various cutter thicknesses. There isn't much difference here between a slitting saw arbor and an arbor for a gear cutter. Generally for a vertical mill you keep the arbors short for reasons of deflection yet it is a good idea to have flexibility in length to achieve clearances.
    In a nut shell your question is hard to deal with as any answer will be correct sonetime!! Even the discussions about the keyway are variable though i would suggest a properly sized key is an advantage.
  16. Dec 18, 2017 #16
    wesley
    wesley
    wesley
    Aug 2, 2009
    66
    13
    well thanks every body,to be honest l hope l have not been a pain here over this subject,making the holder am clear about now ,as for the gear cutters well went and looked at past posts on gear cutting etc and have come to the thinking that l am on the wrong track,metric gear cutting set wont do me any good,so have stopped the order , the gears that l want to make are of 48 dp and with the amount that l am wanting to cut , l may as well make my own cutter set or l may be better off cutting them with a single point fly cutter that a lot on here seem to favour for the shallow 48 dp gear set up,dam have a lot to learn,but will get there.
    wes
  17. Dec 18, 2017 #17
    RM-MN
    RM-MN
    RM-MN
    Active Member
    Feb 25, 2017
    38
    7
  18. Dec 19, 2017 #18
    kiwi2
    kiwi2
    kiwi2
    Mar 13, 2012
    222
    75
    Hi,
    Here are some pictures of the holder I made for 22mm gear cutters. Sorry for the quality - my phone is not great at closeups. I made it by brazing a short length of 5/8" (16mm) steel to a piece of 1 1/4" (32mm) steel. The 22mm section which fits into the cutter needs to be strictly in line with the 5/8" section or the cutter won't cut with all it's teeth. I made sure of this by holding the 5/8" section in a collet that I knew to be running true. If you don't have this, it's better to start with a longer length of 1 1/4" steel and turn both the 16mm and 22mm sections between cenres to ensure they are concentric. The 22mm section needs to be a snug fit in the cutter so it would be best to wait till you have the cutter before making the holder.
    With the forces encountered on our small mills, I've never had a problem with the cutter spinning in the holder even though I haven't provided a keyway.
    Hope this helps.
    Alan C.
    BaronJ and wesley like this.
  19. Dec 19, 2017 #19
    kiwi2
    kiwi2
    kiwi2
    Mar 13, 2012
    222
    75
    Sorry,
    I forgot to say that the 5/8" section is held in a collet on the mill.
  20. Dec 19, 2017 #20
    wesley
    wesley
    wesley
    Aug 2, 2009
    66
    13
    Great pictures very helpful,and to baron who has helped me with the gear cutter and made my mind a lot clearer on this subject now,with this forum l dont feel that l am on my own,yes l have a lot to learn ,but you make make easier .
    many thanks to you all.
    wes
    bazmak likes this.
Share This Page
