metalnwood
Active Member
- Nov 15, 2009
- 31
- 0
Hi, I decided my first engine would be a simple one and this one had a good set of drawings.
I just needed to convert a couple of things to metric and get some 6mm drill rod and I am now ready. The plans are simple enough but I have stumbled across a problem which I am sure someone can confirm for me..
There is a machine screw which goes through the upright in to the cylinder block. I guess the idea is that this with the spring has a light tension to keep the cylinder block against the upright, right? Either that or it is just providing a pivot. Either way the screw should thread in to something but on the plans I don't see a thread in the cylinder block for it or in the upright.
I am not familiar with imperial so perhaps one of these sizes is correct for a tap, not sure. Any confirmation would be appreciated,
pdf is here to have a quick look. http://littlemachineshop.com/Products/Drawings/2593OscillatingEngineAssembly.pdf
Thanks,
Jason
Thanks,
Jason
