Engine Projects
Help Support HMEM:
ShopShoe
Senior Member
Quite an array of engines and other projects there. Engineering Eye-Candy for sure.
Thank You for Posting,
--ShopShoe
Bentwings
Minnesota
I’ve scoured the internet for an operating 28 cylinder model p&w engine. Has anyone built one?
awake
HMEM Supporter
North Carolina
Steve, I had to read that three times before it clicked. I kept thinking, "if they were able to start the engine, why didn't it keep running?" Then I realized that you meant - I think you meant - that they started building the engine.
Bentwings
Minnesota
Sorry for the confusion I finally found a patent drawing of the articulated counterweight and the reason for it. The guy that invented it was much higher educated than me. He said the crankshaft was too heavy so he had it lightened. Knowing that the minute flexing might cause issues down the road so he did extensive vibration analysis and endless calculations then came up with this device. Since a model engine can’t produce anywhere near the hp per pound that the big motor could I don’t think it would be needed. The model crank may look like a pretzel but it would be very difficult to get into dynamics like the full size one. Being a hotrodder I probably would push the model to its limits just to see how fast it could run. I would base it on Mr. Hogsons’ 18 cylinder motor. If the model motor could make 15 hp at 4-5000 rpm it would be fantastic. I plan on designing a brake Dtho for testing Too. Several have done these for cart motors so it’s no too difficult or expensive. It’s a matter of bailing out of two of my other expensive hobbies. Classic cars and boats. I have one of each for sale cheap.
stevehuckss396
Model Engineer
HMEM Supporter
Sterling Heights, MI
I got out of the hot rods and into model building. Now I only buy a half a gallon of turbo blue a year instead of 22 gallons every two or three weeks.
Bentwings
Minnesota
Ha,ha nitro is $40 a gallon now. I think it’s $840 for a 42 gallon drum. That size has to do with home land security. More on that later if interested. I don’t have any nitro capable motors so I don’t worry about it.
