drilling mm
Lorenz
Hello,
I'm from Holland and we work here with mm (milimeter)
I have got plans in inches and I try to calculate them in mm.
In the instructions stands: drill the hole, ( 1/8 inch. )
Now I calculated: 1/8 = 12.5% ( 100: 8 x 1 )
so 12.5 % = 0.125.
0.125 x 1 inch (25.4 mm) = 3.175 mm
is that a hole from 3 mm? 3,1 mm? or 3.2 mm?
that is very importand to know.
I hope my post is clear :D
thanks!
If the hole is for a rod to pass through then you would be better off using 3.0mm as that is a readily available metric size, far easier than trying to turn down 4mm material to 3.2mm.
The same applies if its a clearance hole for a thread, as you will likely substitute an M3 thread instead of 1/8" whitworth, 5BA, 5-44, etc.
Jason
Very true, you need to consider standard stock sizes available to you for things like shafts etc. You could of course buy imperial (inch) stock AND drillbits though! :eek:
Vic.
Hi Lorenz
When I get plans in inches, I convert them with 1" = 24 mm; so 1/4" = 6 mm, 1/8" = 3 mm, 1/16" = 1.5 mm... no more problems with standard size for drills, mills, reamers, etc.
A simple Excel sheet makes the conversion fast & easy.
The engine is 5% smaller than the original, but it's not a problem for me.
For threads I use the standard metric size closer to the plans.
Roberto
View attachment 1 inches to 24 mm conversion.xls
oke! thanks for the reactions,
The tabels are very useful,
I like the way from roberto, that is easy to use.
thanks a lot! Thm:
Robertos method is useful for bar stock designs but may present problems when working with castings.
Also it does not equate well to stock sizes once you work on larger engines as 1" would be better converted to 25mm (stock size) than 24mm.
Jason
