CX601 Milling Machine
Help Support HMEM:
Courierdog
HMEM Supporter
Edmonton, AB, CA
Brian:
Here is what you need.
Mini Shop Crane
Or it at least it looks interesting and for a person of your talents, I would suggest pneumatic tires to make it easier moving around the shop and out to the truck.
The part I like is you can build it to suit your home and situation which best suits your needs.
It is strictly for vertical lifting. There is no Boom or any means to extend a weight in the horizontal plain other than moving the entire Crane from point A to Point B
Courierdog
HMEM Supporter
Edmonton, AB, CA
I had another look. I would suggest a different approach to the actual lifting method.
1. and electric Winch
2. a chain fall
3. a block and tackle using as many pulleys as required to make the lifting weight manageable with Carpal Tunnel Syndrome.
goldstar31
Twixt Tyne and Tees
I hope that I am not offending anyone but my thoughts and actions may be worth a thought or two.
Provided there is no problems which are severe mentally and physically, there is no reason that I can see to prevent people of they are still in clining to carry on machining into quite late in lif e. I'm almost 91!
However, I have made dramatic alterations( and really should make more) because I am no longer fit enough to even consider heavy-ish tooling and certainly not blocks and tackles.
I'm even connsidring whether to dispense with my milling machine and tackling jobs which we all managed on a vertical slide-- in the olden days.
I've updated my lathe to one which is the same but hopefully, requires and w ill reqire less attention in whatever future holds. Again, when that time inevitably comes, there will be a workshop which will be desirable and not the subject and attention of the tire kickers who waste time of those who have the responsibility of finalising things.
Like many of advancing age, I have more than one lathe. It has saved vast amounts of time and effort in not having to change tooling and, in my case, the second lathe was incredibly cheap. In other w ords as someone who has 'done cost accountancy, recognises that machinery not only reduces in value but-- horror of horrors- takes on a negative value .
So my thoughts. I'd be delighted to hear yours
Norman
Richard Hed
Seattle
Over here, its called a "Sack Barrow" !
Whoa, that's really great--learnd another new word. a "sack Barrow", must originally come from the same meaning as wheel barrow, a barrow of course is a pig. Did the ancient English, perhaps, use pigs for work like camels?
goldstar31
Twixt Tyne and Tees
Chinese:)
The railway stuff of 4feet 8 and a half inches is older than the Romans. There are ruts formed from chariots running along The Roman Wall and obviously older than that. George Stephenson, the railway pioneer ived nearby-- and copied the gauge. In wood first!
BaronJ
Grumpy Old Git.
York, North Yorkshire
Hi Richard,
Up here in Yorkshire and Scotland , the word "Barrow" often gets pronounced "Barra". Barra is also the most southerly of the inhabited islands in the Outer Hebrides part of the Western Ilse.
goldstar31
Twixt Tyne and Tees
A Barrow is also a tumulus in pre- historic times.
Now they have found that Stonehenge was moved from the Nort of Sccotland to the South of England
Heady stuff and just discovered
trlvn
near Toronto, Canada
... Brian is a gentleman
Interesting. Why did you feel the need to point that out? I certainly haven't written anything that suggests otherwise.
... the luxury of being able to drive to Toronto from Barrie. There are more of us out in the "Left Overshoe" of Canada who while we may live near a city that happens to have a BusyBeeTools outlet. As has also been said Only Toronto is authorized to perform repairs or ship out spares.
You might recheck Brian's first interaction with BusyBee. It was all done remotely and they sent him a new control board immediately. Why his experience was different from others in the West, apart from the time difference, I can't say.
... I have lived In the Maritimes, In Ontario, and Alberta and there is a huge difference in treatment if you live anywhere but Toronto the Blessed, oh and by the way you also must life on the correct side of the tracks as well.
Wow, there is an awful lot to unpack there but that is just too far from the raison d'etre of this board.
Craig
Richard Hed
Seattle
Well, just so that anyone concerned will know: I . . . am NOT a gentleman, not at all, I am rude and crude and slap women just for fun. Rather, I am . . . a SCHOLAR! I am also a coward, if threatened by a woman bigger than me, I RUN! But in my spare time, when not spuming naughty words or slapping the helpless, I READ!
trlvn
Craig, Sorry, but you are a very confused individual.
What a delightful person you are. We may disagree but I haven't disparaged you. Yet.
... the way a customer should be treated in respect to the business. CUSTOMER SERVICE.
I will again point out that Brian's mill went down on March 3 and I believe he received the repaired head back on March 11. Are we really calling that bad customer service?
Note that I only ever commented on his experience--no others.
Craig
goldstar31
Twixt Tyne and Tees
Well? Yes.
But the World rotates on the interaction of Land, Labour and Capital and arguably Enterprise.
In a modest sort of way, hobby workshops are obtained-- or not. Rational comments would be welcome--- as it is bloody cold, raining and I have been locked down in this awful pandemic for 13 months.
Norman
ajoeiam
MN
snip
Hang in there - - - - more lock down to come - - - - we are a very long way from done with this particular virus at this point.
In fact the UN, IIRC, was suggesting at least one more year - - - - knowing how accurate bureaucratic estimates are I'd suggest that said estimate is likely quite optimistic!
Linz
Active Member
Ardrossan, Alberta
An update on what is happening with the mill. I went over to BusyBee sales outlet today in Barrie and picked up the power head for my mill. (Toronto BusyBee ships it up to my local BusyBee with no charge to me.) They refunded $67 to me because the filter board they had originally sent me was not the problem. They put a new power cord on the mill and a new fuse holder. They charged me $15 for the new power cord and nothing for the new fuse holder. Two hours labour cost $100.00 I'm okay with this. It is a good milling machine and I am very happy with it. I used my cherry-picker engine hoist to unload it from my truck and onto my two wheel pallet truck, then maneuvered it from my garage into my office. It is extremely heavy. I may enlist the help of my younger son to get it off the pallet truck and back into position on the mill. My hands are bad with carpal tunnel syndrome right now, so I'm in no great rush.
That was good of them to refund on the board. Driving to Concord seems to be the answer to lack of parts /service at the local stores. I wish I could do that. Although, driving the 3400kms might be quicker then waiting for them to return a call. Maneuvering these machines and parts can certainly be a chore. Your in home work room looks extremely convenient but also limiting on the hoisting equipment that can be used.
Brian Rupnow
Design Engineer
Barrie, Ontario, Canada
Together again---All my tears have stopped falling---Okay, well, maybe we're not all country music fans. This morning, with the help of my cherry picker engine hoist and armed with absolute faith in myself, I put the head back on my mill.---And yes, I did actually plug it into power and turn it on just to make damned sure that it really did run before I put it back on the machine. I was going to get my younger son to come over and help me, but I'd really rather work alone, and he is out and about with his job every day and I am still concerned about catching Covid. I consider it rather miraculous that the mill quit working on almost the same day that my carpal tunnel syndrome rendered both hands rather useless. I've taken good advantage of the "downtime" that resulted from the mill breaking down, and my hands are doing much better now. I still have to tram the mill and fix a few wires in place, but it will be back in production by the end of today. In terms of money, it's cost me about $125 and a trip to Toronto, but neither is a big deal for me.---Brian Rupnow
