Coilmotorworks
Active Member
Two polarity reversals per stroke?
Ok, I am hooked. I will try to build one. I want to try putting an air gap in the middle of the piston (slug). I have always wanted to build a steam locomotive replica using solenoids and this design you have here looks like it is what is needed to work properly. Thanks for sharing the design.
As for the crank if it were up to me I would make a pinned and soldered crank.
Coil Motor Works
[ame]http://www.youtube.com/watch?v=1UiPdkCwDIc[/ame]
Coil Motor Works
