- Dec 28, 2008
- 1,731
- 9
To start off this building season I decided on this simple two cylinder. Its compact and about the same size as most of the previous engines I have built. The main point of interest is the valve location that allows it to control two cylinders reminiscent of a Stuart Sirus or Sun.
I) The cylinder block was band saw cut oversize from common aluminum bar stock. Using a fly cutter in the MD it was accurately machined to size indicated in the plans. Precision micrometers and square were used to verify its dimensions and squareness before proceeding.
2) Here's the MD and set up used to size the cylinder block. The photos show the mess left by one sizing operation. Subsequent photos will be "staged" to conceal this reality that we all face.
3)The cylinder block was first drilled to 1/2" and then brought to a finished dimension of .750 using a small boring head and bar. To accurately place all the bored, drilled, and taped holes scribed intersection locations were verified using the calibrated hand wheels on the MD. Drilled holes are taped using the chuck to accurately locate and center the hand- tapping operation. You can see a small diameter aluminum turning disc that I use to minimize tap breakage.
4) This last photo shows the finished cylinder block and pistons.The transfer ports at the top of the bore were done using a 1/8" end mill. The intake and exhaust openings on opposite sides of the block were tapped 10-40 for the 3/16" model pipe that will be used.
I'll post more parts and pics as the build progresses.
-MB
-MB
