Bolton No.2 Mill Engine
Discussion in 'A Work In Progress' started by jcreasey, Sep 11, 2019.
  1. Nov 5, 2019 #21
    Jacob P.
    Jacob P.
    Jacob P.
    New Member
    Nov 2, 2019
    1
    1
    Gender:
    Male
    York, PA
    Great progress! Once I get more experience with machining, I’m going to tackle a PM Research No. 5 vertical steam engine build. I have the castings and have been brainstorming how to go about the machining. I’m very much a beginner, and these photos will be useful in guiding me how to go about it. Keep up the good work! Looking forward to seeing the finished product.
    jcreasey likes this.
  2. Nov 5, 2019 #22
    jcreasey
    jcreasey
    jcreasey
    Active Member
    Jun 20, 2015
    27
    44
    If you are a bit nervous making an engine from castings it's a good idea to try making an engine from bar stock first. Those are great because if you make a mistake you can easily replace any part. There are a lot of wonderful designs by Elmer Verburg for which plans are freely available.
    Good luck with it in any case!
    LorenOtto likes this.
  3. Nov 6, 2019 #23
    bobden72
    bobden72
    bobden72
    Jul 18, 2012
    119
    41
    Gender:
    Male
    Occupation:
    Retired
    Plymouth UK
    Looking good
  4. Nov 11, 2019 #24
    petep
    petep
    petep
    Member HMEM Lifetime Supporter HMEM Supporter
    Jul 18, 2012
    18
    29
    Gender:
    Male
    Occupation:
    Pharmacist
    Launceston, Tasmania
    What an amazing build. Thanks for sharing it with us. You make it look so easy - I'm half way through building the Bolton No 7 & have found it more difficult than I originally thought using castings. Your photo's are brilliant too. Maybe you could give us a few tips on how you get such good photos. Thanks again. Cheers Pete
  5. Nov 11, 2019 #25
    jcreasey
    jcreasey
    jcreasey
    Active Member
    Jun 20, 2015
    27
    44
    Thanks Pete!
    I take all of my photos with my iphone. It's a fairly recent one I think about a year old. I think it's important to make sure the lens is clean. I often retake a photo after cleaning some schmutz off of my lens. Also I think it's a good idea to have plenty of light but to avoid a single point source of light that produces hard shadows. Also I like to zoom in a bit so everything is nice and big.
    Good luck with your engine. It's definitely a challenge building from castings! Mine is even trickier because the castings I have are version 1 and the prints are the revised version. I'm finding the differences as I go which is an added challenge.
    Some more photos coming soon as I did a bunch more on the weekend.
  6. Nov 11, 2019 #26
    jcreasey
    jcreasey
    jcreasey
    Active Member
    Jun 20, 2015
    27
    44
    This instalment covers my initial work on making the crankshaft. At the moment it is still a round disk but I am planning to make it a bit more interesting shape in due course. Once again the castings were a bit meagre for this part so I sliced off half an inch of bronze bar I had sitting on the shelf.
    First step was to face it and drill and tap the center. This was supposed to be 1/4 40 but I went down to 3/16 - 40 so that I would have a nice firm boss for the flywheel to but up against.
    I didn't take any photos but the next step was to put a thread on the end of the crankshaft.
    I just single pointed that as I wanted to do everything possible to get things concentric.
    Once that was done I screwed the two parts together and mounted them between centers.
    I didn't bother with a dog as there was enough friction to drive things as I was taking nice light cuts with a very sharp tool.
    This let me clean up the crankshaft part ensuring it was as concentic as possible to the main shaft.
    Turning between centers makes it very easy to flip things over to finish the other side.
    Not much room for a dog here so it was lucky I could get by with just friction.
    Lots of stickout on this tool but it was very sharp and still cut ok.
    I still use the faceplate just to make sure my spindle nose is protected.
    Now that everything is concentric and parallel I detached the shaft again and setup in the mill using some parallels and a little V block so that I could drill and tap the hole for the crank.
    That's about it for the crankshaft disk. Later on I will need to reduce it's thickness and diameter but I am waiting till a few more parts are done so that I can figure out where everything goes. A lot of stuff is coming together around the cross head and it is all quite interdependant.
  7. Nov 13, 2019 #27
    jcreasey
    jcreasey
    jcreasey
    Active Member
    Jun 20, 2015
    27
    44
    Next task was the con-rod. This started out as a little gunmetal casting which I cleaned up in the mill.
    Once I had things nice and flat I drilled the two required holes. The plan called for 3" between centers but I decided to let the casting be my guide and put things in the middle of each end.
    Then I needed to solve the problem of holding this thing in the lathe so I decided as always to do it the most complicated way possible.
    I made up some brass fixtures to clamp each end so that I could hold one end in the chuck and support the other side with the center. I made some pins to fit the holes each end and threaded the other end.
    If you haven't tried a solid tungsten slitting saw I would highly recommend them!
    I just used a screw on the small end. Once everything was aligned and tightened I squirted each end with super glue for good measure.
    Final step was to use my taper turning attachment to machine a nice taper. The part was flipped to do the other side. I used a nice rounded form tool to give me some nice curved shoulders each end.
    And there you have it. The plan called for a 1/16 relief on the side between the two ends. I did that on the back side but it didn't look as nice so I left the outer side unrelieved. When I cleaned up the sides of the big end I just supported it on pins through each end. This gave it a jaunty non parallel look. I'm not sure if I like that too much but I guess it will be ok.
    Thanks for reading and for the great comments. More soon!
  8. Nov 13, 2019 #28
    delalio
    delalio
    delalio
    New Member
    Sep 23, 2019
    1
    1
    IE
    This is coming along beautifully! Well done!!
  9. Nov 13, 2019 #29
    Larry G.
    Larry G.
    Larry G.
    New Member
    Nov 5, 2019
    1
    2
    Gender:
    Male
    NJ, USA
    Thank you for taking the time to post excellent photos and detailed explanations.
    Where some model makers would have been satisfied to touch up the connecting rod with a bit of filing and belt sanding, your "most complicated way possible" approach produced a fine result.
    Your toolmaker mindset is producing an excellent product.
    I look forward to seeing more.
    Larry
    LorenOtto and jcreasey like this.
  10. Nov 15, 2019 #30
    LorenOtto
    LorenOtto
    LorenOtto
    Active Member HMEM Supporter
    Feb 18, 2012
    34
    3
    Thank you for posting your build. You photos are very clear and the extra steps you take to turn a dreary set of castings into a thing of beauty and elegance are extraordinary. I am enjoying watching from afar.
    Loren
  11. Nov 15, 2019 #31
    Emers
    Emers
    Emers
    New Member
    Jul 17, 2019
    2
    2
    Gender:
    Male
    Sydney Australia
    Enjoying your build I am a new model builder myself ( 1 year) I like to watch every bodies builds keep up the great work.
Share This Page
