compressor man
Hi Guys, I have started work on elmers #33 mill engine. I am having a lot of trouble making heads or tails on the cylinder portion of the plans. The cylinder is a little bit oddly shaped, it appears to have 2 flat sides and each end is circular in order to accept the round heads. My questions..
1. The upper left drawing seems to be the layout for one of the flat sides, where is the layout for the second?
2. Rather than giving the hole spacings as measured from the edge of the piece, they seem to be measured from the centerline of it (example, in the upper left drawing there are 4 holes that are 3/8" apart. Are they centered on the centerline of the actual block or the centerline of the bore (they have different centerlines)?
3. In the left side drawing that is second from the top what is the dotted line with the arrows on each end suppossed to represent?
In my mind it seems that these drawings are incomplete but I do not think that is the case. Rather it is my inexperience that is unable to fill in the blanks so to speak. If anyone has built this engine and can fill in those blanks for me I would be quite grateful.
Sorry for the fuzzy drawing, it just seemed to copy and paste that way.
Chris
Chris
