Band saw upgrade
Norway
Hi,
I have completed some very useful mods on my band saw that I would like to share with you. This band saw is really a delight to work with. It cuts effortless trough anything and leaves a very clean cut. It can be tilted to vertical position and be used as a table band saw.
However, the table that came with it was flimsy and required some work to install. Also cutting small parts was difficult because the wise does not grip smaller parts.
I made a new table that can be attached and removed just by pushing it on and pulling it off. Done in two seconds. Next I drilled some holes here and there on the base plate to accommodate standard clamping tools. This way I can hold down pretty small parts.
Next I made a nice work holder for the table. With this I can hold small parts very steady and I can apply the necessary force on the work with ease without danger of cutting my fingers. It also accommodate standard clamping tools.
Some great ideas there Rudy. Thanks for sharing.
Nice work! I think if someone would sell these saws with some simple mods already in place they'd have a going market.
I especially like your slide-on table. I've seen folding tables, screwed tables, etc. but I don't want to mess around making changes. I want transformer saw!! Pull, twist, click, click, done. Next!
I'm make mods to mine: Hydraulic down-feed control (in process), table, chip catcher (need to improve it), light (LED sewing machine light), etc. But this is sort of a 'filler' project.
Pete
The use of a milling machine clamping set is brilliant. Luckily I still have all of my fingers so timing of your shared ideas is perfect.
Thanks
Hello Rudy,
A great idea, half way through converting mine. I am using 5 mm aluminium plate. Norm
Thanks
Speaking of clamping sets, I've made up some for a Mini pallet at work and those little guys come in handy in ways you never imagined. The Mini pallet idea is something I can recommend to anybody.
In the context of this tread though it never occurred to me to use them on a band saw. It is a good idea.
Great work. I had a saw similar to yours. When using it vertical I often wished it had a padded seat.
Hi Rudy,
Nice upgrades!
Here's a link to what I did to mine...
http://www.modelenginemaker.com/index.php/topic,6363.0.html
Like your idea of using the clamping set either on the saw or table, I've got a 4" drill vice that fits on the base IF I take the moving jaw off....should modify that so that's not needed! Oh the most useful thing I did beside putting the saw on 4 casters is adding a little extra to the fix jaw & for want of another name " the outer fix jaw, stops the cut off being grabbed by the blade & possibly twisting it. The new material end stop is also brilliant, can adjust to 0.1 mm & get consistent lengths with ease!
Cheers Kerrin
Kerrin, that base extension was a really good one! Ill do that to.
Agree, the fixed wise is crap. With the small wise attachment and clamps for larger works we probably won’t need the original wise very often. However, the “counterweight” screw will make it usable for more than long works.
I think I will go the small wise/clamp approach and see if I will miss the original wise.
