Arduino project finished
gld
HMEM Supporting Member
Tarkio, Missouri
I finally got my Arduino project finished.
The box is from Digi-Key. http://www.digikey.com/product-detail/en/CU-3283/377-1218-ND/428968
Button switches also from Digi-Key. http://www.digikey.com/product-search/en?vendor=0&keywords=eg1311-nd
Port for the Gecko connection.
This port was cut by hand as was the hole for the USB connector.
Many thanks to cfellows for the inspiration to start this project, and Gary Liming for his sketch. The switches are working with no modification to the sketch.
And here is another finished project for the Arduino.
Gary,
A couple of quick questions. Are you having any issues with the switches? Such as missed inputs or switch Bounce. And which of Liming's sketches are you using? The degree only or the Divisions and Degrees? Does it reverse for you by the sketch?
Chuck
Gary,
Chuck
The switches are working fine. I'm using V 2.3, Divisions and Degrees. No problems yet with right & left switches.
Can you post a link to V2.3? Gary Liming says you don't have to be a Digital Machinist subscriber to download it.
Chuck
