Mechanicboy
- Jul 10, 2013
- 957
- 346
In semidieselengine the fuel is hitting the hot part of hot bulb and there will evaporate and ignite fuel, in fact the semidieselengine is less sensitive for bad atomized fuel and will run. If the exhaust smoke is white, it means too much fuel or not enough compression of ratio. Is the hot bulb glowing before you tried to start the engine?
1: Adjust smaller amount of fuel
2: Increase compression of ratio
3: Reduce loss of heat from hot bulb to cylinder head
