Inset options? repairing half nut - can I feed right to left back side of bore in reverse and use a 16er 8 acme insert -or will the tooth profile be wrong. Will make a new barrel and then cut away remains of threads and solder in .Bob
...Was also thinking of using industrial epoxy to bond new sleeve to old block , not sure if this would be ok?? ...
Bobbin shape is very possible - was planning to leave the sleeve intact until set and then cut in half. If I bore out the old threads accurately (make a jig to hold or use the apron) to match the OD of the new sleeve was thinking this would align ok??? Bob
