Hi Maryak,
you are indeed making very good progress, congratulations.
I am sure the project will end up a great success.
One minor point to consider though...... when it comes to silver soldering..... the use of aluminium as a NON-STICK fixing aid is frought with danger.... the typical melting point of ALI is around 660deg C .
I don't know which grade of SILVER SOLDER you are using, however, assuming that you are using something like EasyFlo 2.. 42% silver content + it has 25% cadmium in it's make up, then this melts at around 610 deg C - 620deg C...pretty close to Ali.
If, as I suspect, cadmium based solders are not available in OZ then the nearest equivalent CADMIUM free type SILVERFLO 40 (40% Silver) then this melts at 650deg C - 710degC.
SILVERFLO 24 (24% Silver) melts at 740deg C - 780deg C.
Obviously you have got away with it in this instance, however, I thought it worth warning you of the possible problem.
When you come to solder on the transfer passage I would suggest you fit a RUSTY bolt and nut through the inlet stub just to make sure it does not move when re-heating, and use some soft iron wire, bound round the cylinder to hold the transfer passage in place.
Don't push your luck and try using an ALI clamp or fixture.... I would hate to see all that good work wrecked for the sake of using the wrong method.
Please don't think I am being critical, nothing could be further from the truth, I am just pointing out a possible problem area for you and others who may be following this thread to consider.
Best regards.
SandyC
;D
