Brian40
- Mar 24, 2014
- 142
- 152
Thanks for the O ring info I had made a note of that from reading your other builds.
so its the cam!!! the blank was turned between centres so I can return later to form the bearings etc but for the moment it was left at base circle diameter for max strength.
After forming the blank, it was on to the mill to cut away the base circle to produce the cam. that put the pucker factor up a bit I can tell you.
Brian.
Brian.
