- Jan 17, 2009
- 887
- 81
Ok Chaps Her's my starter for ten
The Loco is a 2-4-0 LNWR Precedent Class to LBSC's Mabel Design. Hers a photo of a model built by a chap in Canada
I choose a LNWR loco because both my Grandfather and Great Grandfather had both been loco drivers with the Company. LBSC otherwise known a Curly Lawrence serialised the construction in Model Engineer in the sixties, just before died, his last of over fifty model loco designs. The Precedent class of Loco earned the nick name JUMBO by its crews from its power and work rate, with one engine HARDWICK clocking up over 2 million miles in just over ten years, this Loco is know preserved at the national railway museum in York. I like the idea that my predecessor may have drove this engine
I bought a set of castings and drawings from Reeves and being on the lazy side ordered set of laser cut frames from another company this saved me a fair bit of work (and hacksaw blades) as they also marked out all the holes positions.
Just to give you a update a few pics of progress so far
This is the assembled frame with the wheels in place
This is the crank axle with con rods and eccentric rods.
The cylinder and slide valves with gland packing
The Alan valve linkage
The reversing bracket and wheel
The cylinder loosely assembled with cross head
That more or less bring you up to date with progress so far, next job is to assemble the cylinder and linkage etc into the frame set the timing and try and get it running under air.
Im doing a more detailed write up on another forum but if its OK Ill copy in over onto her as well.
Stew
Stew
