Kaleb
Senior Member
- Jan 3, 2010
- 272
- 27
After a bit of head scratching and talking to others in the know about diesels, I decided that it may be possible to build a diesel using an off the shelf injector from a Yanmar or Hatz engine using the facilities I currently have available for most of the work. The only thing I can think of which I'll have to go to someone else for are the teeth on the gears.
It will have a 60mm bore and a 74mm stroke. The flywheels will be 220mm in diameter.
Here's some of the CAD I've done so far. I've still got a way to go here, but it should give some idea as to the appearance of the finished engine. I will be making plans available once I've got a complete set done.
A scrounging trip a while ago yielded a pair of main bearings.
These are the gear blanks. I've still got some work to do on the larger one. The smaller one just needs the teeth cut and holes drilled and tapped for grub screws.
